Configuring Environment Variables
An environment variable is a variable whose value can affect the way a running container will behave. You can modify environment variables even after workloads are deployed, increasing flexibility in workload configuration.
The function of setting environment variables on CCE is the same as that of specifying ENV in a Dockerfile.
After a container is started, do not modify configurations in the container. If configurations in the container are modified (for example, passwords, certificates, and environment variables of a containerized application are added to the container), the configurations will be lost after the container restarts and container services will become abnormal. An example scenario of container restart is pod rescheduling due to node anomalies.
Configurations must be imported to a container as arguments. Otherwise, configurations will be lost after the container restarts.
Environment variables can be set in the following modes:
- Custom: Enter the environment variable name and parameter value.
- Added from ConfigMap key: Import all keys in a ConfigMap as environment variables.
- Added from ConfigMap: Import a key in a ConfigMap as the value of an environment variable.
- Added from secret: Import all keys in a secret as environment variables.
- Added from secret key: Import the value of a key in a secret as the value of an environment variable.
- Variable value/reference: Use the field defined by a pod as the value of the environment variable.
- Resource Reference: The value of Request or Limit defined by the container is used as the value of the environment variable.
Adding Environment Variables
- Log in to the CCE console.
- Click the cluster name to go to the cluster console, choose Workloads in the navigation pane, and click the Create Workload in the upper right corner.
- When creating a workload, modify the container information in Container Settings and click the Environment Variables tab.
- Configure environment variables.
YAML Example
apiVersion: apps/v1
kind: Deployment
namespace: default
replicas: 1
selector:
matchLabels:
app: env-example
template:
labels:
app: env-example
containers:
- name: container-1
image: nginx:alpine
imagePullPolicy: Always
resources:
requests:
cpu: 250m
memory: 512Mi
limits:
cpu: 250m
memory: 512Mi
env:
- name: key # Custom
value: value
- name: key1 # Added from ConfigMap key
valueFrom:
configMapKeyRef:
key: configmap_key
- name: key2 # Added from secret key
valueFrom:
secretKeyRef:
key: secret_key
- name: key3 # Variable reference, which uses the field defined by a pod as the value of the environment variable.
valueFrom:
fieldRef:
apiVersion: v1
fieldPath: metadata.name
- name: key4 # Resource reference, which uses the field defined by a container as the value of the environment variable.
valueFrom:
resourceFieldRef:
containerName: container1
resource: limits.cpu
divisor: 1
envFrom:
- configMapRef: # Added from ConfigMap
- secretRef: # Added from secret
imagePullSecrets:
- name: default-secret
Viewing Environment Variables
If the contents of configmap-example and secret-example are as follows:
$ kubectl get configmap configmap-example -oyaml apiVersion: v1 data: configmap_key: configmap_value kind: ConfigMap ... $ kubectl get secret secret-example -oyaml apiVersion: v1 data: secret_key: c2VjcmV0X3ZhbHVl # c2VjcmV0X3ZhbHVl is the value of secret_value in Base64 mode. kind: Secret ...
The environment variables in the pod are as follows:
$ kubectl get pod NAME READY STATUS RESTARTS AGE env-example-695b759569-lx9jp 1/1 Running 0 17m $ kubectl exec env-example-695b759569-lx9jp -- printenv / # env key=value # Custom environment variable ey1=configmap_value # Added from ConfigMap key key2=secret_value # Added from secret key key3=env-example-695b759569-lx9jp # metadata.name defined by the pod key4=1 # limits.cpu defined by container1. The value is rounded up, in unit of cores. configmap_key=configmap_value # Added from ConfigMap. The key value in the original ConfigMap key is directly imported. secret_key=secret_value # Added from key. The key value in the original secret is directly imported.
