Help Center/
      API Gateway/
        Dedicated API Gateway User Guide (Paris Region)/
        Monitoring & Analysis/
        API Monitoring/
      Viewing Metrics
        Updated on 2023-12-20 GMT+08:00
Viewing Metrics
Cloud Eye monitors the status of your APIs and allows you to view their metrics.
Viewing Metrics of an API
- Go to the APIG console.
 - Select a gateway at the top of the navigation pane.
- In the navigation pane, choose API Management > API Groups.
- Click a group name.
 - In the left pane of the APIs tab, select an API.
- View metrics of the API in the Monitoring area.
 - Click More to view more metrics on the Cloud Eye console.
     The monitoring data is retained for two days. To retain the data for a longer period, save it to an OBS bucket.
Viewing Metrics of an API group
- In the navigation pane, choose Monitoring & Analysis > API Monitoring.
 - Select the target API group and view its metrics.
   Parent topic: API Monitoring
