Debugging an API
After creating an API, debug it on the APIG console by setting HTTP headers and body to verify whether the API is running normally.
  - APIs with backend request paths containing variables cannot be debugged.
 - If an API has been bound with a request throttling policy, the policy will not work during debugging of the API.
 - The maximum backend timeout is 60s for API debugging.
You have set up the backend service of the API.
- Go to the APIG console.
 - Select a dedicated gateway at the top of the navigation pane.
- Choose API Management > API Groups.
 - Click a group name.
 - On the APIs tab, select the target API and click Debug.
 - Configure the URL and request parameters of the API.
Select a request method, protocol, and domain name, and set request parameters.
Select the debugging or an independent domain name. If you select a wildcard domain name, specify the subdomain name.
     If the independent domain name you select is a wildcard domain name, you can use any of its subdomain names to access all APIs in the group to which the domain name is bound.
For example, if a wildcard domain name is *.aaa.com, the subdomain name can be default.aaa.com or 1.aaa.com.
 - Click Debug.
 - The box on the lower right displays the response of the API request.
- If the debugging is successful, an HTTP status code starting with 2 and response details are displayed.
 - If the request fails to be sent, an HTTP status code 4xx or 5xx is displayed. For details, see Error Codes.
 - You can send more requests with different parameters and values to verify the API.
Follow-Up Operations
After the API is successfully debugged, publish the API in a specific environment so that the API can be called by users. To ensure security, create policies for the API.
