Notes and Constraints
To change the default restrictions, increase the quota by referring to
  It takes 5 to 10 seconds for a new or modified APIG resource to take effect.
       Item  |
       Default Restriction  |
       Modifiable  |
       Gateways  |
       5  |
       API groups  |
       1500  |
       APIs  |
       Number of APIs for each gateway edition:
       Backend policies  |
       5  |
       Apps (credentials)  |
       50. The app quota includes the apps (credentials) you have created.  |
       Request throttling policies  |
       Environments  |
       10  |
       Signature keys  |
       200  |
       Access control policies  |
       100  |
       VPC channels (load balance channels)  |
       200  |
       Variables  |
       You can create a maximum of 50 variables for an API group in each environment.  |
       Independent domain names  |
       A maximum of five independent domain names can be bound to an API group.  |
       ECSs  |
       A maximum of 10 ECSs can be added to a VPC channel.  |
       Parameters  |
       A maximum of 50 parameters can be created for an API.  |
       API publication records  |
       A maximum of 10 publication records of an API can be retained for each environment.  |
       API access rate  |
       Up to 6000 times per second  |
       Excluded apps  |
       A maximum of 30 excluded apps can be added to a request throttling policy.  |
       Excluded tenants  |
       A maximum of 30 excluded tenants can be added to a request throttling policy.  |
       Access to a subdomain name (debugging domain name)  |
       A subdomain name (debugging domain name) can be accessed up to 1000 times a day.  |
       x  |
       Maximum size of an API request package  |
       12 MB  |
       TLS protocol  |
       TLS 1.1 and TLS 1.2 are supported. TLS 1.2 is recommended.  |
       Custom authorizers  |
       50  |
       x  |
       Plug-ins  |
       500  |
