Help Center/
      API Gateway/
        User Guide (Paris Region)/
        API Opening/
        Environment Management/
      Deleting an Environment
        Updated on 2022-02-21 GMT+08:00
You can delete environments you no longer require.
You have created an environment.
 - Click
 in the upper left corner and choose API Gateway. - In the navigation pane, choose API Publishing > Environments.
 - In the Operation column of the environment you want to delete, click Delete.
     You can delete an environment only if no APIs have been published in the environment.
 - Click Yes.
   Parent topic: Environment Management
