Updated on 2024-12-31 GMT+08:00
User ID
User ID for running the container. This parameter is optional. The default value 1000 is recommended.
If the UID needs to be specified, its value must be within the specified range. The value ranges of different resource pools are as follows:
  • Public resource pool: 1000 to 65535
  • Dedicated resource pool: 0 to 65535
