Updated on 2025-05-29 GMT+08:00
Output Path
The path for storing the batch prediction results. You can select an empty folder you created.
A manifest file will be generated in the output directory of the batch service.
- Assume that the output path is //test-bucket/test/. The result is stored in the following path:
OBS bucket or directory name ├── test-bucket │ ├── test │ │ ├── infer-result-{{task_id}}.manifest │ │ ├── infer-result-{{task_id}} │ │ │ ├── 1.jpg_result.txt │ │ │ ├── 2.jpg_result.txt
- File format:
- The file name is infer-result-{{task_id}}.manifest, where task_id is the batch task ID, which is the only ID for a batch service.
- If a large number of files need to be processed, multiple manifest files may be generated with the same suffix .manifest and are distinguished by suffix, for example, infer-result-{{task_id}}_1.manifest.
- The infer-result-{{task_id}} directory is created in the manifest directory to store the file processing result.
- The manifest file content is in JSON format. Each line describes the output result of a piece of input data.
- The content contains multiple fields:
- source: input data description, which is the same as that of the input manifest file
- result: file processing result, which can be SUCCESSFUL or FAILED
- inference-loc: displayed when result is SUCCESSFUL. It is the output result path in the format of obs://{{Bucket name}}/{{Object name}}
- error_message: displayed when result is FAILED. It is the output error information.
