Using a Codec-accelerated Node
CCE allows you to create codec-accelerated nodes. To ensure these nodes function properly, you must install the necessary drivers and software packages using either a pre- or post-installation command.
Preparations
Submit a service ticket and consult the ECS service to obtain the driver and software packages of the codec-accelerated node.
| Software Package | Installation Package Name Format | Example |
| PCIe driver package | vastai-pci-xxx.rpm | vastai-pci-d3-2-v2-6-a1-6-sp5-xhs-hwtype-video_00.24.06.04_x86_64.rpm |
| Driver installation dependency package | dkms-xxx.rpm | dkms-2.6.1-6.hce2.noarch.rpm |
| GCC installation package | gcc_make.tar.gz | gcc_make.tar.gz |
| container-runtime package | vastai-docker-xxx.rpm | vastai-docker-0.3.8.0-1.el7.x86_64.rpm |
| VastStream SDK installation package | vaststream-xxx.tar.gz | vaststream-2.1.1_sp3-20230717-d00e24d-x86-av.tar.gz |
| Tools package | tools-xxx.tar.gz | tools-2.2.1-davp1-202307251819-08bf515-x86-tools.tar.gz |
You are advised to pack these installation packages, upload them to an OBS bucket, and make sure that the bucket address is accessible during node creation. The install_pkg.tar.gz package is used as an example.
Installing Drivers and Software Packages Using the Pre- or Post-installation Commands
- If the version of a cluster is earlier than v1.23.17-r0, v1.25.12-r0, v1.27.9-r0, v1.28.7-r0, or v1.29.3-r0, you can use post-installation command to deliver the driver and software installation commands.
After clusters are upgraded to v1.23.17-r0, v1.25.12-r0, v1.27.9-r0, v1.28.7-r0, v1.29.3-r0, or later, if a node pool contains a codec-accelerated node, you need to install drivers and software packages using pre-installation command.
- If the version of a cluster is 1.23.17-r0, 1.25.12-r0, 1.27.9-r0, 1.28.7-r0, 1.29.3-r0, or later, CCE detects the vc1-200t model and automatically modifies the containerd configurations. You can use pre-installation command to deliver the driver and software package installation commands.
Verifying the Installation
- After the node is installed, log in to it.
- Check whether the driver is installed:
lsmod |grep vastai_pci
If information similar to the following is displayed, the installation is successful.
- Check the driver version:
cat /dev/vastai0_version |grep Driver
Information similar to the following is displayed.
- Run the following command to check whether tools are installed:
vasmi list
