Access Mode
It specifies how a PV can be mounted. CCE supports ReadWriteMany and ReadWriteOnce. If it is set to ReadWriteMany, a volume will be mounted to multiple nodes in read/write mode. If the parameter is set to ReadWriteOnce, a volume will be mounted to a single node in read/write mode.
Value Range
ReadWriteMany or ReadWriteOnce
Default Value
None
Modifiable
No. This parameter can only be configured during initialization.
Suggestions
Configure this parameter based on the storage volume type. For example, set the parameter to ReadWriteOnce for block storage and local PVs, and set the parameter to ReadWriteMany for file storage and object storage.
