Creation Method
It specifies whether a PV is created dynamically or is bound statically.
It is not a Kubernetes native field. It is used by the CCE frontend to distinguish the PVC binding mode (dynamic or static).
Value Range
Dynamically provision, Use existing, or Create new
Default Value
Modifiable
No. This parameter can only be configured during initialization.
Suggestions
If you have created storage resources using IaaS, select existing PVs or newly created PVs. Otherwise, use dynamically provisioned PVs.
