Help Center/ Cloud Container Engine/ Drawer/ Configuration Reference/ Node Pools/ Container Engine Settings/ Limit on the Number of Handles in a Container
Updated on 2025-11-11 GMT+08:00
It controls how many handles can exist in a container.
Value Range
Greater than 0
Default Value
1048576
Modifiable
Yes
Scope
CCE standard and Turbo clusters
Suggestions
Configure this parameter based on the specific scenario. Typically, the default value is used.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
