Pod Toleration Limit Add-on
With Kubernetes, you can enable admission add-ons to limit and manage Kubernetes API objects (like pods, Services, and Deployments) prior to modifying them within a cluster.
This add-on allows cluster administrators to configure the default value and limits of pod tolerations through namespaces for fine-grained control over pod scheduling and key resource protection. Unless otherwise specified, keep the default settings.
Value Range
true or false
Configure the list of plugins to be enabled as needed. Unless otherwise specified, keep the default settings.
Default Value
false
Modifiable
Yes
Scope
CCE standard and Turbo clusters
Suggestions
Ensure that you comprehend the impact of the desired plugins. Enabling a plugin for a cluster without assessing it can result in the cluster behaving unexpectedly.
