Maximum Number of Container Network Interfaces Pre-Bound to a Node
When the number of container network interfaces bound to a node exceeds what is supported, no more container network interfaces will be pre-bound. Checking the maximum number of pre-bound container network interfaces is enabled only when the value of this parameter is at least equal to the minimum number of container network interfaces (nic-minimum-target) bound to a node.
The value must be a positive integer. The default value of 0 specifies that the check on the maximum number of container network interfaces pre-bound to a node is disabled. If the number you entered exceeds the container network interface quota of the node, the network interface quota will be used.
Value Range
0 to 256
Default Value
0
Modifiable
Yes
Scope
CCE Turbo clusters
Suggestions
To configure the upper limit, set the parameter to the maximum number of pods that can run on most nodes.
