Ascend HCCS-Interconnected NPU Affinity for Preferential Scheduling
It controls whether Ascend HCCS-interconnected NPU affinity is enabled for preferential scheduling. If the scheduling is enabled, resources will be preferentially scheduled to a node's NPU1980 chips to reduce resource fragments.
Value Range
true or false
Default Value
true
Modifiable
Yes
Scope
CCE standard and Turbo clusters
Suggestions
Enable this scheduling by default for NPU-powered clusters. Disable it if NPUs are not used.
