Backup Locking
To prevent backups from being deleted by mistake or maliciously, you can lock your backup vaults to improve data security.
Once enabled, all backups in the vault enter a WORM (write once, read many) state. No one can delete backups whose retention periods have not expired.
Notes and Constraints
- After backup locking is enabled, it cannot be disabled, and resources cannot be dissociated or migrated away from the vault.
- After backup locking is enabled, policy-based backups will be retained until their policy expires, at which point they are deleted automatically.
- Manual backups are not affected by backup locking. They can be manually deleted.
- After backup locking is enabled, pay-per-use vaults cannot be deleted if they contain backups, but yearly/monthly vaults can be unsubscribed from.
- Backup locking does not affect normal backup, restoration, and replication operations.
FAQ
