How Do I Handle Special Characters in Hudi Partitioned Columns?
Question
In a Hudi partitioned table, if a partition column value contains special characters, for example colons (:), the write operation will fail. The following error information is displayed:
2026-04-23 15:13:48,615 | ERROR | task-result-getter-1 | Task 0 in stage 122.0 failed 4 times; aborting job | org.apache.spark.scheduler.TaskSetManager.logError(Logging.scala:76) 2026-04-23 15:13:48,621 | WARN | main | Closing write client | org.apache.hudi.HoodieSparkSqlWriterInternal.handleWriteClientClosure(HoodieSparkSqlWriter.scala:752) Job aborted due to stage failure: Task 0 in stage 122.0 failed 4 times, most recent failure: Lost task 0.3 in stage 122.0 (TID 717) (52-190-2-29 executor 4): java.lang.RuntimeException: org.apache.hudi.exception.HoodieException: org.apache.hudi.exception.HoodieException: java.lang.IllegalArgumentException: java.net.URISyntaxException: Illegal character in scheme name at index 3: par=aa:aa
Answer
When you create a Hudi partitioned table, the partition column must not contain special characters, such as colons (:), commas (,), hyphens (-), or question marks (?).
