Updated on 2026-06-27 GMT+08:00
Using Multi-Joins in Flink SQL
Flink SQL supports multi-joins, which effectively reduces intermediate states in multi-table join scenarios.
Notes and Constraints
  • Multi-joins do not support the Join-to-Live feature.
  • Snapshots taken before and after a multi-join operation are incompatible.
  • When using multi-joins to combine multiple tables, the join keys for all tables must be identical.
  • This section applies only to MRS 3.6.0-LTS.1 and later.
How to Use
To enable the multi-join function, add the custom parameter table.optimizer.multi-join.enabled and set its value to true on the Flink job development page of the FlinkServer web UI. For details, see Creating a FlinkServer Job.
Example SQL statement:
CREATE TABLE datagen1 (id int, f1 int, PRIMARY KEY (id) NOT ENFORCED)
WITH
    'connector' = 'datagen',
    'rows-per-second' = '1'
CREATE TABLE datagen2 (id int, f2 int, PRIMARY KEY (id) NOT ENFORCED)
WITH
CREATE TABLE datagen3 (id int, f3 int, PRIMARY KEY (id) NOT ENFORCED)
WITH
CREATE TABLE datagen5 (id int, f5 int, PRIMARY KEY (id) NOT ENFORCED)
WITH
CREATE TABLE datagen6 (id int, f6 int, PRIMARY KEY (id) NOT ENFORCED)
WITH
CREATE TABLE print (id int, f1 int, f2 int, f3 int, f5 int, f6 int)
WITH
  ('connector' = 'print');
insert into
  print
select
  datagen1.id,
  datagen1.f1,
  datagen2.f2,
  datagen3.f3,
  datagen5.f5,
  datagen6.f6
from
  datagen1
  left join datagen2 on datagen1.id = datagen2.id
  and datagen2.id > 2
  join datagen3 on datagen1.id = datagen3.id
  and datagen3.id > 3
  right join datagen5 on datagen1.id = datagen5.id
  and datagen5.id > 5
  full outer join datagen6 on datagen1.id = datagen6.id
  and datagen6.id > 6
  and datagen1.id > 1;
