Why Does Spark Fail to Query Data Written by the Union Statement Running on Tez?
Symptom
Hive uses the Tez engine to execute union-related statements to write data. After Hive is switched to the Spark engine for query, no data is found.
Solution
When Hive uses the Tez engine to execute the union-related statement, the generated output file is stored in the HIVE_UNION_SUBDIR directory. After Hive is switched back to the Spark engine, files in the directory are not read by default. Therefore, data in the HIVE_UNION_SUBDIR directory is not queried.
In this case, you can set set mapreduce.input.fileinputformat.input.dir.recursive to true to enable union optimization and determine whether to read data in the directory.
