Performing Operations on a Hudi Table Using Spark SQL
  This section applies only to MRS 3.5.0-LTS or later.
This section describes how to use Hudi with Spark SQLs.
You have created a user and added the user to user groups hadoop (primary group) and hive on FusionInsight Manager.
- Download and install the Hudi client. For details, see Installing a Client.
     Currently, Hudi is integrated in Spark. You only need to download the Spark client on FusionInsight Manager. For example, the client installation directory is /opt/client.
 - Log in to the node where the client is installed as user root and run the following command:
cd /opt/client
 - Run the following commands to load environment variables:
source bigdata_env
source Hudi/component_env
kinit Created user
     - You need to change the password of the created user, and then run the kinit command to log in to the system again.
 - In normal mode (Kerberos authentication disabled), you do not need to run the kinit command.
 - If multiple services are installed, run the component_env command of the source Spark and then the component_env command of the source Hudi after you run the source bigdata_env command.
 - Start Spark SQL.
