Using the MultiJoin Operator in Flink SQL
This section applies only to MRS 3.5.0 or later.
Joining wide tables with Flink's FULL OUTER JOIN operator increases backend pressure and degrades performance, due to the need to manage state for both matched and unmatched records from both tables. You can use MultiJoin operator to combine wide tables, doubling the computing performance.
Restrictions on Using the MultiJoin Operator in Flink SQL
- The MultiJoin operator supports only FULL OUTER JOIN and INNER JOIN.
 - The MultiJoin operator supports only equi-joins. For non-equi joins, you can use a view for filtering.
 - When the MultiJoin operator is used to join multiple tables, the join keys of all tables must be the same.
 - The MultiJoin operator supports only table.exec.state.ttl and does not support table-level TTL or JTL.
 - States of FULL OUTER JOIN are incompatible with MultiJoin states. Jobs cannot be restored using snapshots if you switch between the two operators.
When configuring a Flink job, add custom parameter table.optimizer.multi-join-enabled and set it to true on the Flink job development page of the FlinkServer web UI to use the MultiJoin operator. For details, see Creating a Job.
CREATE TABLE datagen1 ( id int, f1 int, PRIMARY KEY (id) NOT ENFORCED ) WITH ( 'connector' = 'datagen' ); CREATE TABLE datagen2 ( id int, f2 int, PRIMARY KEY (id) NOT ENFORCED ) WITH ( 'connector' = 'datagen' ); CREATE TABLE datagen3 ( id int, f3 int, PRIMARY KEY (id) NOT ENFORCED ) WITH ( 'connector' = 'datagen' ); create view datagen3_view AS select * from datagen3 where id > 1; CREATE TABLE print ( id int, f1 int, f2 int, f3 int, PRIMARY KEY (id) NOT ENFORCED ) WITH ( 'connector' = 'print' ); insert into print select COALESCE(datagen1.id,datagen2.id,datagen3_view.id), datagen1.f1, datagen2.f2, datagen3_view.f3 from datagen1 Full outer join datagen2 on datagen1.id = datagen2.id Full outer join datagen3_view on datagen1.id = datagen3_view.id;
