Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using HetuEngine/ Common HetuEngine SQL Syntax/ HetuEngine Auxiliary Command Syntax/ DESCRIBE OUTPUT
Updated on 2024-12-13 GMT+08:00
DESCRIBE OUTPUT
Syntax
DESCRIBE OUTPUT statement_name
This statement is used to list the output columns of the prepared statement.
Including the column name (or alias), catalog, schema, table name, type, type size (in bytes).
And a boolean value indicating whether the column is an alias.
Example
--PREPARE my_select1 FROM SELECT * FROM fruit; DESCRIBE OUTPUT my_select1; --PREPARE my_select2 FROM SELECT count(*) as my_count, 1+2 FROM fruit; DESCRIBE OUTPUT my_select2; --PREPARE my_create FROM CREATE TABLE foo AS SELECT * FROM fruit; DESCRIBE OUTPUT my_create;
Parent topic: HetuEngine Auxiliary Command Syntax
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
