On this page
Show all
Set Digest Functions
Updated on 2024-12-13 GMT+08:00
Overview
HetuEngine provides several functions that use the MinHash technique.
MinHash quickly estimates how similar two sets based on their Jaccard similarity coefficients. It is usually used in data mining to detect almost the same web pages at scale. By using this information, search engines effectively avoid displaying two web pages that are nearly identical in search results.
The following example shows how to use set digest functions to estimate the similarity between texts. The input texts are split into 4-shingles by the ngrams() function. (The texts are divided into consecutive subsequences each is 4 characters long, and each subsequence is called a shingle or gram.) They are used to create a set digest of each initial text. The set digests are compared with each other to obtain an approximation of similarity of their initial texts.
WITH text_input(id, text) AS (
         VALUES
             (1, 'The quick brown fox jumps over the lazy dog'),
             (2, 'The quick and the lazy'),
             (3, 'The quick brown fox jumps over the dog')
    text_ngrams(id, ngrams) AS (
        SELECT id,
                transform(
                  ngrams(
                    split(text, ' '),
                    4
                  token -> array_join(token, ' ')
         FROM text_input
     minhash_digest(id, digest) AS (
         SELECT id,
                (SELECT make_set_digest(v) FROM unnest(ngrams) u(v))
         FROM text_ngrams
     setdigest_side_by_side(id1, digest1, id2, digest2) AS (
         SELECT m1.id as id1,
                m1.digest as digest1,
                m2.id as id2,
                m2.digest as digest2
         FROM (SELECT id, digest FROM minhash_digest) m1
         JOIN (SELECT id, digest FROM minhash_digest) m2
           ON m1.id != m2.id AND m1.id < m2.id
SELECT id1,
       id2,
       intersection_cardinality(digest1, digest2) AS intersection_cardinality,
       jaccard_index(digest1, digest2)
            AS jaccard_index
FROM setdigest_side_by_side
ORDER BY id1, id2;
 id1 | id2 | intersection_cardinality | jaccard_index
   1 |   2 |                        0 |           0.0
   1 |   3 |                        4 |           0.6
   2 |   3 |                        0 |           0.0
(3 rows)
The above list indicates that, as expected, the texts with IDs 1 and 3 are similar.
Data sketches can be serialized to varbinary or deserialized from varbinary. Varbinary can be used to store data sketches.
Function
  • make_set_digest(x) → setdigest
    Description: Composes all input values of x into a setdigest.
    SELECT make_set_digest(value) FROM (VALUES 1, 2, 3) T(value);
                          _col0
     01 10 00 00 00 02 0b 03 00 80 03 44 00 00 58 3d
     5b 80 20 08 de 00 20 00 00 03 00 00 00 a8 c0 76
     6c a0 20 08 de 4a c4 05 fb b7 03 44 00 0c 8b 48
     b2 39 58 3d 5b 01 00 01 00 01 00
    (1 row)
    SELECT make_set_digest(value) FROM (VALUES 'Trino', 'SQL', 'on', 'everything') T(value);
                          _col0
     01 14 00 00 00 02 0b 04 00 c0 8c 7d 1e c0 75 c9
     2d c0 1a 1a 66 03 11 c3 a5 00 20 00 00 04 00 00
     00 06 e5 2d 45 05 11 c3 a5 48 85 6b d5 e0 8c 7d
     1e b9 1a 8a 39 ff 75 c9 2d 02 ad 0c 7c ed 1a 1a
     66 01 00 01 00 01 00 01 00
    (1 row)
  • merge_set_digest(setdigest) → setdigest
    Description: Returns the setdigest of the aggregate union of the individual setdigest structures.
  • cardinality(setdigest) → long
    Description: Returns the cardinality of the setdigest from its internal HyperLogLog component.
    SELECT cardinality(make_set_digest(value)) FROM (VALUES 1, 2, 2, 3, 3,4, 4, 4, 5) T(value); -- 5
  • intersection_cardinality(x, y) → long
    Description: Returns the estimation for the cardinality of the intersection of the two set digests. x and y must be of the setdigest type.
    SELECT intersection_cardinality(make_set_digest(v1), make_set_digest(v2)) FROM (VALUES (1, 1), (NULL, 2), (2, 3), (3, 4)) T(v1, v2); -- 3
  • jaccard_index(x, y) → double
    Description: Returns the estimation of Jaccard index for the two set digests.aries. x and y must be of the setdigest type.
    SELECT jaccard_index(make_set_digest(v1), make_set_digest(v2)) FROM (VALUES (1, 1), (NULL,2), (2, 3), (NULL, 4)) T(v1, v2); -- 0.5
  • hash_counts(x)
    Description: Returns a map containing the Murmur3Hash128 hashed values and the count of their occurrences within the internal MinHash structure belonging to x. x must be of the setdigest type.
    SELECT hash_counts(make_set_digest(value)) FROM (VALUES 1, 1, 1, 2, 2) T(value); -- {19144387141682250=3, -2447670524089286488=2}
