On this page
Map Functions and Operators
Updated on 2024-12-13 GMT+08:00
Subscript Operator: []
Description: The [] operator is used to retrieve a value corresponding to a given key from a mapping.
select age_map['li'] from (values (map(array['li','wang'],array[15,27]))) as table_age(age_map);-- 15
Map Functions
  • cardinality(x)
    Description: Returns the cardinality of map x.
    select cardinality(map(array['num1','num2'],array[11,12]));-- 2
  • element_at(map(K, V), key)
    Description: Returns the value of key in a map. If the map does not contain the key, null is returned.
    select element_at(map(array['num1','num2'],array[11,12]),'num1'); --11
    select element_at(map(array['num1','num2'],array[11,12]),'num3');-- NULL
  • map()
    Description: Returns an empty map.
    select map();-- {}
  • map(array(K), array(V)) -> map(K, V)
    Description: Returns a map based on the given key-value pair array. The map_agg() and multimap_agg() functions in the aggregate function can also be used to generate maps.
    SELECT map(ARRAY[1,3],ARRAY[2,4]);-- {1=2, 3=4}
  • map_from_entries(array(row(K, V))) -> map(K, V)
    Description: Generates a map using a given array.
    SELECT map_from_entries(ARRAY[(1, 'x'), (2, 'y')]); --  {1=x, 2=y}
  • multimap_from_entries(array(row(K, V))) -> map(K, array(V))
    Description: Returns a composite map based on a given row array. Each key can correspond to multiple values.
    SELECT multimap_from_entries(ARRAY[(1, 'x'), (2, 'y'), (1, 'z')]); -- {1=[x, z], 2=[y]}
  • map_entries(map(K, V)) -> array(row(K, V))
    Description: Generates a row array using the given map.
    SELECT map_entries(MAP(ARRAY[1, 2], ARRAY['x', 'y'])); --  [{1, x}, {2, y}]
  • map_concat(map1(K, V), map2(K, V), ..., mapN(K, V))
    Description: Returns the union of all the given maps. If a key is found in multiple given maps, that key's value in the resulting map comes from the last one of those maps. In the following example, key a uses the value 10 of the last map.
    select map_concat(map(ARRAY['a','b'],ARRAY[1,2]),map(ARRAY['a', 'c'], ARRAY[10, 20]));
           _col0
     {a=10, b=2, c=20}
    (1 row)
  • map_filter(map(K, V), function(K, V, boolean)) -> map(K, V)
    Description: Constructs a new map using only the entry that maps the given function to true.
    SELECT map_filter(MAP(ARRAY[], ARRAY[]), (k, v) -> true); -- {}
    SELECT map_filter(MAP(ARRAY[10, 20, 30], ARRAY['a', NULL, 'c']), (k, v) -> v IS NOT NULL); -- {10=a, 30=c}
    SELECT map_filter(MAP(ARRAY['k1', 'k2', 'k3'], ARRAY[20, 3, 15]), (k, v) -> v > 10); -- {k3=15, k1=20}
  • map_keys(x(K, V)) -> array(K)
    Description: Returns all arrays constructed by keys in a map.
    select map_keys(map(array['num1','num2'],array[11,12])); -- [num1, num2]
  • map_values(x(K, V)) -> array(V)
    Description: Returns all value-constructed arrays in a map.
    select map_values(map(array['num1','num2'],array[11,12]));-- [11, 12]
  • map_zip_with(map(K, V1), map(K, V2), function(K, V1, V2, V3))
    Description: Merges two given maps into a map by applying the function to a pair of values with the same key. For keys that appear only in one map, null is passed as the value for the missing key.
    SELECT map_zip_with(MAP(ARRAY[1, 2, 3], ARRAY['a', 'b', 'c']), -- {1 -> ad, 2 -> be, 3 -> cf}
                         MAP(ARRAY[1, 2, 3], ARRAY['d', 'e', 'f']),
                         (k, v1, v2) -> concat(v1, v2));
           _col0
     {1=ad, 2=be, 3=cf}
    (1 row)
    SELECT map_zip_with(MAP(ARRAY['k1','k2'],ARRAY[1,2]),Map(ARRAY['K2','k3'],ARRAY[4,9]),(k,v1,v2)->(v1,v2));  -- {k3={NULL, 9}, k1={1, NULL}, k2={2, NULL}, K2={NULL, 4}}
                                           _col0
    (1 row)
     SELECT map_zip_with(MAP(ARRAY['a', 'b', 'c'], ARRAY[1, 8, 27]), -- {a -> a1, b -> b4, c -> c9}
                         MAP(ARRAY['a', 'b', 'c'], ARRAY[1, 2, 3]),
                         (k, v1, v2) -> k || CAST(v1/v2 AS VARCHAR));
           _col0
     {a=a1, b=b4, c=c9}
    (1 row)
  • transform_keys(map(K1, V), function(K1, V, K2)) -> map(K2, V)
    Description: For each entry in the map, map the key value K1 to the new key value K2 and keep the corresponding value unchanged.
    SELECT transform_keys(MAP(ARRAY[], ARRAY[]), (k, v) -> k + 1); -- {}
    SELECT transform_keys(MAP(ARRAY [1, 2, 3], ARRAY ['a', 'b', 'c']), (k, v) -> k + 1); -- {2=a, 3=b, 4=c}
    SELECT transform_keys(MAP(ARRAY ['a', 'b', 'c'], ARRAY [1, 2, 3]), (k, v) -> v * v); -- {1=1, 9=3, 4=2}
    SELECT transform_keys(MAP(ARRAY ['a', 'b'], ARRAY [1, 2]), (k, v) -> k || CAST(v as VARCHAR)); --  {a1=1, b2=2}
    SELECT transform_keys(MAP(ARRAY [1, 2], ARRAY [1.0, 1.4]), (k, v) -> MAP(ARRAY[1, 2], ARRAY['one', 'two'])[k]); -- {two=1.4, one=1.0}
  • size(x) → bigint
    Description: Returns the capacity of Map(x) x.
    select size(map(array['num1','num2'],array[11,12])); --2
  • transform_values(map(K, V1), function(K, V2, V2)) -> map(K, V2)
    Description: Maps value V1 to value V2 for each entry in the map and keeps the corresponding key unchanged.
    SELECT transform_values(MAP(ARRAY[], ARRAY[]), (k, v) -> v + 1); -- {}
    SELECT transform_values(MAP(ARRAY [1, 2, 3], ARRAY [10, 20, 30]), (k, v) -> v + k); -- {1=11, 2=22, 3=33}
    SELECT transform_values(MAP(ARRAY [1, 2, 3], ARRAY ['a', 'b', 'c']), (k, v) -> k * k); -- {1=1, 2=4, 3=9}
    SELECT transform_values(MAP(ARRAY ['a', 'b'], ARRAY [1, 2]), (k, v) -> k || CAST(v as VARCHAR)); --  {a=a1, b=b2}
    SELECT transform_values(MAP(ARRAY [1, 2], ARRAY [1.0, 1.4]),(k, v) -> MAP(ARRAY[1, 2], ARRAY['one', 'two'])[k] || '_' || CAST(v AS VARCHAR)); -- {1=one_1.0, 2=two_1.4}
