On this page
Show all
REWRITE HINT
Updated on 2024-12-13 GMT+08:00
This statement can be used together with a SELECT statement to rewrite a query using a specified materialized view, which accelerates the execution of the query statement. A hint must be provided at the beginning of a query. Currently, the following two types of hints are supported:
  • NOREWRITE
    Disables query rewrite. Format: /*+ NOREWRITE */
  • REWRITE(materialized_view_name ..)
    Rewrites a query based on the known materialized view name. You can enter multiple materialized view names and separate them by spaces. A materialized view name must be fully qualified.
    Format: /*+ REWRITE(mv1 mv2 ..) */
Example
  • Forcibly execute the original SQL query without rewriting the query.
    /*+ NOREWRITE */ SELECT c1,c2 FROM table;
  • Rewrite a query using a specified materialized view.
    SET SESSION materialized_view_rewrite_enabled=true; -- Enable the function of query rewrite using materialized views.
    CREATE TABLE t1 (id int, c1 varchar);
    INSERT INTO t1 VALUES (1,'abc'), (2,'abc2'), (3,'abc3'), (4,'abc4'), (5,'abc5'),(6,'abc6');
    CREATE TABLE t2 (id1 int, c1 varchar);
    INSERT INTO t2 VALUES (1,'abc'), (2,'abc2'), (3,'abc3'), (4,'abc4'), (5,'abc5'),(6,'abc6');
    -- Create a materialized view for a SQL query and create materialized views for the subqueries contained in the query.
    CREATE MATERIALIZED VIEW mv.tpcds.test7 AS SELECT a.id,b.c1 FROM (SELECT id FROM t1 WHERE id>5) as a,(SELECT id1,c1 FROM t2 WHERE id1>4) AS b WHERE a.id = b.id1;
    CREATE MATERIALIZED VIEW mv.tpcds.test6a AS SELECT id FROM t1 WHERE id>5;
    CREATE MATERIALIZED VIEW mv.tpcds.test6b AS SELECT id1,c1 FROM t2 WHERE id1>4;
    -- Rewrite a query using the materialized view of a specified subquery.
    EXPLAIN /*+ REWRITE(mv.tpcds.test6a mv.tpcds.test6b) */ SELECT a.id,b.c1 FROM (SELECT id FROM t1 WHERE id>5) AS a,(SELECT id1,c1 FROM t2 WHERE id1>4) AS b WHERE a.id = b.id1;
                                                             Query Plan
     Output[id, c1]
     │   Layout: [id:integer, c1:varchar]
     │   Estimates: {rows: ? (?), cpu: ?, memory: ?, network: ?}
     └─ RemoteExchange[GATHER]
        └─ InnerJoin[("id" = "id1")][$hashvalue, $hashvalue_22]
           │   Distribution: PARTITIONED
           ├─ RemoteExchange[REPARTITION][$hashvalue]
           │  │   Layout: [id:integer, $hashvalue:bigint]
           │  │   Estimates: {rows: ? (?), cpu: ?, memory: 0B, network: ?}
           │  └─ ScanProject[table = hive:tpcds:test6a]
           │         Layout: [id:integer, $hashvalue_21:bigint]
           │         Estimates: {rows: ? (?), cpu: ?, memory: 0B, network: 0B}/{rows: ? (?), cpu: ?, memory: 0B, network: 0B}
           │         $hashvalue_21 := combine_hash(BIGINT 0, COALESCE($operator$hash_code(id), BIGINT 0))
           │         id := id:int:0:REGULAR
           └─ LocalExchange[HASH][$hashvalue_22] ("id1")
              │   Layout: [id1:integer, c1:varchar, $hashvalue_22:bigint]
              └─ RemoteExchange[REPARTITION][$hashvalue_23]
                 │   Layout: [id1:integer, c1:varchar, $hashvalue_23:bigint]
                 └─ ScanProject[table = hive:tpcds:test6b]
                        Layout: [id1:integer, c1:varchar, $hashvalue_24:bigint]
                        $hashvalue_24 := combine_hash(BIGINT 0, COALESCE($operator$hash_code(id1), BIGINT 0))
                        id1 := id1:int:0:REGULAR
                        c1 := c1:string:1:REGULAR
    (1 row)
    -- Rewrite a query using the materialized view of a specified SQL query.
    EXPLAIN SELECT a.id,b.c1 FROM (SELECT id FROM t1 WHERE id>5) AS a,(SELECT id1,c1 FROM t2 WHERE id1>4) AS b WHERE a.id = b.id1;
                                 Query Plan
     Output[id, c1]
        └─ TableScan[table = hive:tpcds:test7]
    (1 row)
