Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using HetuEngine/ Common HetuEngine SQL Syntax/ HetuEngine DDL SQL Syntax/ SHOW CREATE MATERIALIZED VIEW
Updated on 2024-12-13 GMT+08:00
Syntax
SHOW CREATE MATERIALIZED VIEW materialized_view_name
This statement is used to display the SQL statements that can be used to create a materialized view.
Example
Displays the SQL statements for creating the materialized view.
hetuengine:tpcds_2gb> show create materialized view mv.tpcds.test;
Create Materialized View
CREATE MATERIALIZED VIEW mv.tpcds.test ( c1, id )
WITH (
storage_table = 'mppdb.tpcds.test'
) AS
SELECT
c1
, id
FROM
t1
WHERE (id < 7) Parent topic: HetuEngine DDL SQL Syntax
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
