On this page
SHOW TABLE/PARTITION EXTENDED
Updated on 2024-12-13 GMT+08:00
Syntax
SHOW TABLE EXTENDED [IN | FROM schema_name] LIKE 'identifier_with_wildcards' [PARTITION (partition_spec)]
This statement is used to display details about a table or partition.
Regular expressions can be used to match multiple tables at the same time, but cannot be used to match partitions.
The displayed information includes basic table information and file system information. The file system information includes the total number of files, total file size, maximum file length, minimum file length, last access time, and last update time. For a specified partition, its file system information is provided, instead of the file system information of the table where the partition is located.
Parameters
  • IN | FROM schema_name
    This parameter specifies the schema name. If this parameter is not specified, the current schema is used by default.
  • LIKE 'identifier_with_wildcards'
    identifier_with_wildcards supports only rule matching expressions that contain asterisks (*) and vertical bars (|).
    The asterisk (*) can match one or more characters. The vertical bar (|) separates multiple matching rules.
    Spaces at the beginning and end of a rule matching expression are not used for matching.
  • partition_spec
    This parameter is optional. It specifies the partition list using key pairs. Multiple key pairs are separated by commas. Table names do not support fuzzy match when partitions are specified.
Example
-- Data preparation
create schema show_schema;
use show_schema;
create table show_table1(a int,b string);
create table show_table2(a int,b string);
create table from_table1(a int,b string);
create table in_table1(a int,b string);
-- Query the detailed information about tables whose names start with "show".
show table extended  like 'show*';
                                 tab_name
 tableName:show_table1
 owner:admintest
 location:hdfs://hacluster/user/hive/warehouse/show_schema.db/show_table1
 InputFormat:org.apache.hadoop.hive.ql.io.orc.OrcInputFormat
 OutputFormat:org.apache.hadoop.hive.ql.io.orc.OrcOutputFormat
 columns:struct columns {int a,string b}
 partitioned:false
 partitionColumns:
 totalNumberFiles:0
 totalFileSize:0
 tableName:show_table2
 owner:admintest
 location:hdfs://hacluster/user/hive/warehouse/show_schema.db/show_table2
 partitioned:false
 partitionColumns:
 totalNumberFiles:0
 totalFileSize:0
(1 row)
-- Query the detailed information about tables whose names start with "from" or "show".
 show table extended  like 'from*|show*';
                               tab_name
 tableName           show_table1
 owner               admintest
 location            hdfs://hacluster/user/hive/warehouse/show_table1
 InputFormat         org.apache.hadoop.hive.ql.io.orc.OrcInputFormat
 OutputFormat        org.apache.hadoop.hive.ql.io.orc.OrcOutputFormat
 columns             struct columns {int a,string b}
 partitioned         false
 partitionColumns
 totalNumberFiles    0
 totalFileSize       null
 tableName           from_table1
 owner               admintest
 location            hdfs://hacluster/user/hive/warehouse/from_table1
 partitioned         false
 partitionColumns
 totalNumberFiles    0
 totalFileSize       null
 tableName           show_table2
 owner               admintest
 location            hdfs://hacluster/user/hive/warehouse/show_table2
 partitioned         false
 partitionColumns
 totalNumberFiles    0
 totalFileSize       null
(1 row)
-- Query the detailed information about the page_views table in the web schema.
 show table extended from web like 'page*';
                                  tab_name
 tableName:page_views
 owner:admintest
 columns:struct columns {timestamp view_time,bigint user_id,string page_url}
 partitioned:true
 partitionColumns: struct partition_columns {date ds,string country}
 totalNumberFiles:0
 totalFileSize:0
(1 row)
