Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using HetuEngine/ Common HetuEngine SQL Syntax/ HetuEngine DDL SQL Syntax/ SHOW TABLES
Updated on 2024-12-13 GMT+08:00
SHOW TABLES
Syntax
SHOW TABLES [ (FROM | IN) schema ] [ LIKE pattern [ESCAPE escapeChar] ]
This expression is used to list all tables in a specified schema. If no schema is specified, the current schema is used by default.
The optional parameter like is used for keyword-based matching.
Example
--Create a test table.
Create table show_table1(a int);
Create table show_table2(a int);
Create table showtable5(a int);
Create table intable(a int);
Create table fromtable(a int);
-- Match a single character '_'.
show tables in default like 'show_table_';
Table
show_table1
show_table2
(2 rows)
-- Match multiple characters '*' and '%'.
show tables in default like 'show%';
Table
show_table1
show_table2
showtable5
(3 rows)
show tables in default like 'show*';
Table
show_table1
show_table2
showtable5
(3 rows)
-- The escape character is used. In the second example, '_' is used as the filter condition. The result set does not contain showtable5.
show tables in default like 'show_%';
Table
show_table1
show_table2
showtable5
(3 rows)
show tables in default like 'show$_%' ESCAPE '$';
Table
show_table1
show_table2
(2 rows)
-- If multiple conditions are met, query the tables whose names start with show_ or in in default.
show tables in default like 'show$_%|in%' ESCAPE '$';
Table
intable
show_table1
show_table2
(3 rows) Parent topic: HetuEngine DDL SQL Syntax
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
