Help Center/
      MapReduce Service/
        Component Operation Guide (LTS)/
        Using HetuEngine/
        Common HetuEngine SQL Syntax/
        HetuEngine DDL SQL Syntax/
      REFRESH MATERIALIZED VIEW
        Updated on 2024-12-13 GMT+08:00
Syntax
REFRESH MATERIALIZED VIEW materialized_view_name
This statement is used to update data in a materialized view.
You need to obtain the materialized view name in advance.
The following is an example.
Example
hetuengine:tpcds_orc_hive_2> refresh materialized view mv.tpcds.test; REFRESH MATERIALIZED VIEW: 10 rows
   Parent topic: HetuEngine DDL SQL Syntax
