Common Flink SQL Syntax
SELECT and WHERE
Filter using the WHERE clause.
- Example:
SELECT price + tax FROM Orders WHERE id = 10
WITH
WITH provides a way to write auxiliary statements for use in a larger query. These statements, which are often referred to as Common Table Expression (CTE), can be thought of as defining temporary views that exist just for one query.
This statement is available for the Flink in MRS 3.1.2-LTS and later versions only.
Window Aggregation
Queries with a group by window aggregation will compute a single result row per group.
Window Deduplication
Window Deduplication is a special deduplication which removes rows that duplicate over a set of columns, keeping the first one or the last one for each window and partitioned keys.
This statement is available for the Flink in MRS 3.2.0-LTS and later versions only.
- Syntax:
FROM (
SELECT [column_list],
ROW_NUMBER() OVER (PARTITION BY window_start, window_end [, col_key1...]
ORDER BY time_attr [asc|desc]) AS rownum
FROM table_name) -- relation applied windowing TVF
WHERE (rownum = 1 | rownum <=1 | rownum < 2) [AND conditions]
- Example:
SELECT * FROM ( SELECT bidtime, price, item, supplier_id, window_start, window_end, ROW_NUMBER() OVER (PARTITION BY window_start, window_end ORDER BY bidtime DESC) AS rownum FROM TABLE( TUMBLE(TABLE Bid, DESCRIPTOR(bidtime), INTERVAL '10' MINUTES)) ) WHERE rownum <= 1;
Top-N
Top-N queries ask for the N smallest or largest values ordered by columns.
- Syntax:
FROM (
ROW_NUMBER() OVER ([PARTITION BY col1[, col2...]]
ORDER BY col1 [asc|desc][, col2 [asc|desc]...]) AS rownum
FROM table_name)
WHERE rownum <= N [AND conditions]
- Example:
CREATE TABLE ShopSales ( product_id STRING, category STRING, product_name STRING, sales BIGINT ) WITH (...); SELECT * FROM ( SELECT *, ROW_NUMBER() OVER (PARTITION BY category ORDER BY sales DESC) AS row_num FROM ShopSales) WHERE row_num <= 5
