On this page
Common Sqoop Commands and Parameters
Updated on 2024-12-13 GMT+08:00
For more Sqoop command parameters, see the Sqoop official document at https://sqoop.apache.org/docs/1.4.7/SqoopUserGuide.html.
Common Commands
Table 1 Common commands
Command
import
Imports data to a cluster.
export
Exports data of a cluster.
codegen
Obtains data from a table in the database to generate a Java file and compress the file.
create-hive-table
Creates a Hive table.
eval
Executes a SQL statement and view the result.
import-all-tables
Imports all tables in a database to HDFS.
job
Generates a Sqoop job.
list-databases
Lists database names.
list-tables
List table names.
merge
Merges data in different HDFS directories and saves the data to a specified directory.
metastore
Starts the metadata database to record the metadata of a Sqoop job.
help
Prints help information.
version
Prints the version information.
Common Parameters
Table 2 Common parameters
Type
Database connection
--connect
Specifies the URL for connecting to a relational database.
--connection-manager
Specifies the connection manager class.
--driver jdbc
Specifies the driver package for database connection.
--help
--password
Specifies the password for connecting to a database.
--username
Specifies the username for connecting to a database.
--verbose
Prints detailed information on the console.
import parameters
--fields-terminated-by
Specifies the field delimiter, which must be the same as that in a Hive table or HDFS file.
--lines-terminated-by
Specifies the line delimiter, which must be the same as that in a Hive table or HDFS file.
--mysql-delimiters
Specifies the default delimiter settings of MySQL.
export parameters
--input-fields-terminated-by
Specifies the field delimiter.
--input-lines-terminated-by
Specifies the line delimiter.
Hive parameters
--hive-delims-replacement
Replaces characters such as \r and \n in data with user-defined characters.
--hive-drop-import-delims
Removes characters such as \r and \n when data is imported to Hive.
--map-column-hive
Specifies the data type of fields during the generation of a Hive table.
--hive-partition-key
Creates a partition.
--hive-partition-value
Imports data to a specified partition of a database.
--hive-home
Specifies the installation directory for Hive.
--hive-import
Specifies that data is imported from a relational database to Hive.
--hive-overwrite
Overwrites existing Hive data.
--create-hive-table
Creates a Hive table. The default value is false. A destination table will be created if it does not exist.
--hive-table
Specifies a Hive table to which data is to be imported.
--table
Specifies the relational database table.
--columns
Specifies the fields of a relational data table to be imported.
--query
Specifies the query statement for importing the query result.
HCatalog parameters
--hcatalog-database
Specifies a Hive database and imports data to it using HCatalog.
--hcatalog-table
Specifies a Hive table and imports data to it using HCatalog.
-m or --num-mappers
Specifies the number of map tasks used by a Sqoop job.
--split-by
Specifies the column based on which Sqoop splits work units. This parameter is used together with -m.
--target-dir
Specifies the temporary directory of HDFS.
--null-string string
Specifies the string to be written for a null value for string columns.
--null-non-string
Specifies the string to be written for a null value for non-string columns.
--check-column
Specifies the column for determining incremental data import.
--incremental append or lastmodified
Incrementally imports data.
append: appends records, for example, appending records that are greater than the value specified by last-value.
lastmodified: appends data that is modified after the date specified by last-value.
--last-value
Specifies the last value of the check column from the previous import.
--input-null-string
Specifies the string to be interpreted as NULL for string columns.
--input-null-non-string
Specifies the string to be interpreted as null for non-string columns. If this parameter is not specified, NULL will be used.
