Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using Flink/ Creating a FlinkServer Job/ Creating a FlinkServer Job to Interconnect with JDBC
Updated on 2024-12-13 GMT+08:00
This section applies to MRS 3.3.1 and later.
FlinkServer can interconnect with JDBC. This topic uses FlinkServer and Kafka in security mode as an example to describe the DDL definition for JDBC MySQL source tables, sink tables, and dimension tables. This topic also explains the WITH parameters for creating a table and code examples. You will learn how to connect to JDBC on the FlinkServer job management page.
NOTICE:
When "FlinkSQL" is displayed in the command output on the FlinkServer web UI in MRS 3.2.0 or later clusters, the password field in the SQL statement is left blank. Before you submit a job, manually enter the password.
Mapping between Flink SQL and JDBC data types
Flink SQL
MySQL
Oracle
PostgreSQL
SQL Server
BOOLEAN
BOOLEAN
TINYINT(1)
BOOLEAN
BIT
TINYINT
TINYINT
TINYINT
SMALLINT
SMALLINT
TINYINT UNSIGNED
SMALLINT
INT2
SMALLSERIAL
SERIAL2
SMALLINT
INT
INT
MEDIUMINT
SMALLINT UNSIGNED
INTEGER
SERIAL
INT
BIGINT
BIGINT
INT UNSIGNED
BIGINT
BIGSERIAL
BIGINT
FLOAT
FLOAT
BINARY_FLOAT
REAL
FLOAT4
REAL
DOUBLE
DOUBLE
DOUBLE PRECISION
BINARY_DOUBLE
FLOAT8
DOUBLE PRECISION
FLOAT
STRING
CHAR(n)
VARCHAR(n)
TEXT
CHAR(n)
VARCHAR(n)
CLOB
CHAR(n)
CHARACTER(n)
VARCHAR(n)
CHARACTER VARYING(n)
TEXT
CHAR(n)
NCHAR(n)
VARCHAR(n)
NVARCHAR(n)
TEXT
NTEXT
BYTES
BINARY
VARBINARY
BLOB
RAW(s)
BLOB
BYTEA
BINARY(n)
VARBINARY(n)
ARRAY
ARRAY
DATE
DATE
DATE
DATE
DATE
TIME [(p)] [WITHOUT TIMEZONE]
TIME [(p)]
DATE
TIME(0)
TIMESTAMP [(p)] [WITHOUT TIMEZONE]
DATETIME [(p)]
DATETIME
DATETIME2
DECIMAL(20, 0)
BIGINT UNSIGNED
DECIMAL(p, s)
NUMERIC(p, s)
DECIMAL(p, s)
SMALLINT
FLOAT(s)
DOUBLE PRECISION
REAL
NUMBER(p, s)
NUMERIC(p, s)
DECIMAL(p, s)
DECIMAL(p, s)
Cluster where FlinkServer resides:
  • HDFS, Yarn, Kafka, ZooKeeper, and Flink have been installed in the cluster.
  • The client that contains the Kafka service has been installed, for example, in the /opt/client directory.
  • You have created a user with the FlinkServer Admin Privilege (for example, flinkuser) for accessing the Flink web UI by referring to Creating a FlinkServer Role.
JDBC Sink Table (MySQL as an Example)
  1. Create an empty table for receiving data in a database, for example, MySQL database customer_t1.
  2. Log in to Manager as user flinkuser and choose Cluster > Services > Flink. In the Basic Information area, click the link next to Flink WebUI to access the Flink web UI.
  3. Create a Flink SQL job by referring to Creating a FlinkServer Job. On the job development page, configure the job parameters as follows and start the job.
    In Basic Parameter, select Enable CheckPoint, set Time Interval(ms) to 60000, and retain the default value for Mode.
    CREATE TABLE MyUserTable(
      c_customer_sk INTEGER,
      c_customer_name VARCHAR(32)
    ) WITH(
      'connector' = 'jdbc',
      'url' = 'jdbc:mysql://IP address of the MySQL server:MySQL server port/mysql',
      'table-name' = 'customer_t1',
      'username' ='MySQL database username',
      'password' ='Password of the MySQL database user'
    CREATE TABLE KafkaSource (
    ) WITH (
      'connector' = 'kafka',
      'topic' = 'customer_source',
      'properties.bootstrap.servers' = 'Service IP address of the Kafka Broker instance:Kafka port number',
      'properties.group.id' = 'testGroup',
      'scan.startup.mode' = 'latest-offset',
      'value.format' = 'csv',
      'properties.sasl.kerberos.service.name' = 'kafka',  --Delete this parameter if the cluster where FlinkServer is deployed is in non-security mode.
      'properties.security.protocol' = 'SASL_PLAINTEXT',  --Delete this parameter if the cluster where FlinkServer is deployed is in non-security mode.
      'properties.kerberos.domain.name' = 'hadoop.System domain name'  --Delete this parameter if the cluster where FlinkServer is deployed is in non-security mode.
    Insert into
      MyUserTable
    select
    from
      KafkaSource;
    • The IP address and port number of the Kafka broker instance are as follows:
      • To obtain the instance IP address, log in to FusionInsight Manager, choose Cluster > Services > Kafka, click Instance, and query the instance IP address on the instance list page.
      • If Kerberos authentication is enabled for the cluster (the cluster is in security mode), the Broker port number is the value of sasl.port. The default value is 21007.
      • If Kerberos authentication is disabled for the cluster (the cluster is in normal mode), the broker port number is the value of port. The default value is 9092. If the port number is set to 9092, set allow.everyone.if.no.acl.found to true. The procedure is as follows:
        Log in to FusionInsight Manager and choose Cluster > Services > Kafka. Click Configurations then All Configurations. On the page that is displayed, search for allow.everyone.if.no.acl.found, set it to true, and click Save.
    • System domain name: To obtain the value, log in to FusionInsight Manager, choose System > Permission > Domain and Mutual Trust, and check the value of Local Domain.
    • properties.group.id indicates the Kafka user group ID. This parameter is mandatory when Kafka functions as the source.
    • properties.kerberos.domain.name: Set it to hadoop.System domain name. To obtain the actual domain name of the cluster, log in to FusionInsight Manager and choose System > Permission > Domain and Mutual Trust.
  4. On the job management page, check whether the job status is Running.
  5. Execute the following commands to view the topic and write data to Kafka. For details, see Managing Messages in Kafka Topics.
    ./kafka-topics.sh --list --bootstrap-server Service IP address of the Kafka Broker instance:Kafka port --command-config Client directory/Kafka/kafka/config/client.properties
    sh kafka-console-producer.sh --broker-list IP address of the node where Kafka Broker instances reside:Kafka port --topic Topic name --producer.config Client directory/Kafka/kafka/config/producer.properties
    In this example, the topic name is customer_source.
    sh kafka-console-producer.sh --broker-list IP address of the node where the Kafka Broker instance is located:Kafka port --topic customer_source --producer.config /opt/client/Kafka/kafka/config/producer.properties
    Enter the message content.
    3,zhangsan
    4,wangwu
    8,zhaosi
    Press Enter to send the message.
  6. Log in to the MySQL client and run the following statement to check whether the sink table received data:
    Select * from customer_t1;
JDBC Source Table (MySQL as an Example)
  1. Log in to Manager as user flinkuser and choose Cluster > Services > Flink. In the Basic Information area, click the link next to Flink WebUI to access the Flink web UI.
  2. Create a Flink SQL job by referring to Creating a FlinkServer Job. On the job development page, configure the job parameters as follows and start the job.
    In Basic Parameter, select Enable CheckPoint, set Time Interval(ms) to 5000, and retain the default value for Mode.
      --MySQL source table
    ) WITH(
    CREATE TABLE KafkaSink (
      -- Kafka functions as a sink table.
    ) WITH (
      'topic' = 'customer_sink',
    Insert into
      KafkaSink
    select
    from
      MyUserTable;
    • System domain name: You can log in to FusionInsight Manager, choose System > Permission > Domain and Mutual Trust, and check the value of Local Domain.
    • properties.kerberos.domain.name: Set it to hadoop.System domain name. You can log in to FusionInsight Manager and choose System > Permission > Domain and Mutual Trust to view the actual domain name of the cluster.
  3. On the job management page, check whether the job status is Running.
  4. Obtain the required Kafka IP address and port by referring to Managing Messages in Kafka Topics, and run the following command to check whether data is written from the Kafka topic to the sink table:
    sh kafka-console-consumer.sh --topic customer_sink --bootstrap-server IP address of the node where the Kafka instance is deployed:Kafka port number --consumer.config /opt/client/Kafka/kafka/config/ consumer.properties
JDBC Dimension Table (MySQL as an Example)
kafkaSource is used as the fact table, customer_t2 is used as the dimension table, and the result is written to kafkaSink.
  1. Create the dimension table customer_t2 on the MySQL client. An example of the table creation statement is as follows:
    CREATE TABLE customer_t2(
    c_customer_sk INTEGER PRIMARY KEY,
    c_customer_age INTEGER,
    c_customer_address VARCHAR(32)
    INSERT INTO customer_t2 VALUES(1,18,'city a');
    INSERT INTO customer_t2 VALUES(2,14,'city b');
    INSERT INTO customer_t2 VALUES(3,16,'city c');
    INSERT INTO customer_t2 VALUES(4,24,'city d');
    INSERT INTO customer_t2 VALUES(5,32,'city e');
    INSERT INTO customer_t2 VALUES(6,27,'city f');
    INSERT INTO customer_t2 VALUES(7,41,'city a');
    INSERT INTO customer_t2 VALUES(8,35,'city h');
    INSERT INTO customer_t2 VALUES(9,16,'city j');
      -- Kafka as a source table
      c_customer_name VARCHAR(32),
      proctime as proctime()
    ) WITH (
      'properties.bootstrap.servers' = 'Service IP address of the Kafka Broker instance:Kafka port',
      -- Kafka sink table.
    ) WITH (
    CREATE TABLE MyUserTable (
      -- MySQL dimension table
      c_customer_sk INTEGER PRIMARY KEY NOT ENFORCED,
    ) WITH (
      'table-name' = 'customer_t2',
    INSERT INTO
      KafkaSink
    SELECT
      t.c_customer_sk,
      t.c_customer_name,
      d.c_customer_age,
      d.c_customer_address
    FROM
      KafkaSource as t
      JOIN MyUserTable FOR SYSTEM_TIME AS OF t.proctime as d ON t.c_customer_sk = d.c_customer_sk;
  4. Run the following command to check whether data is received in the sink table, that is, check whether data is properly written to the Kafka topic after 5 is performed. For details, see Managing Messages in Kafka Topics.
  5. View the topic and write data to the Kafka topic by referring to Managing Messages in Kafka Topics. After the data is written, view the execution result in the window in 4.
    ./kafka-topics.sh --list Service IP address of the Kafka Broker instance:Kafka port --command-config Client directory/Kafka/kafka/config/client.properties
    sh kafka-console-producer.sh --broker-list IP address of the node where Kafka Broker instances are deployed:Kafka port --topic Topic name --producer.config Client directory/Kafka/kafka/config/producer.properties
    sh kafka-console-producer.sh --broker-list IP address of the node where the Kafka Broker instance is deployed:Kafka port --topic customer_source --producer.config /opt/client/Kafka/kafka/config/producer.properties
    3,zhangsan
    5,zhaosi
    1,xiaoming
    2,liuyang
    7,liubei
    10,guanyu
    20,zhaoyun
    Press Enter to send the message. The output in the kafka-console-consumer window in 4 is as follows:
    3,zhangsan,16,city c
    5,zhaosi,32,city e
    1,xiaoming,18,city a
    2,liuyang,14,city b
    7,liubei,41,city a
