MemArtsCC Logs
Log path: /var/log/Bigdata/memartscc
Archive rule: Automatic compression and archive is enabled for MemArtsCC run logs. When the size of a log file exceeds 50 MB (the size is configurable), the log file is automatically compressed. The number of compressed files can be retained is configurable.
| Log Type | Log File Name | Description |
| Run log | check-sidecar-instance.log | Sidecar health check log |
| check-worker-instance.log | Worker health check log | |
| check-service.log | Health check log of the MemArtsCC service | |
| cleanup-service.log | MemArtsCC service cleanup log | |
| install-service.log | MemArtsCC service installation log | |
| sidecarStartDetail.log | Sidecar startup log | |
| sidecarStopDetail.log | Sidecar stop log | |
| workerStartDetail.log | Worker startup log | |
| workerStopDetail.log | Worker stop log | |
| Worker log | cc-worker-console.Log generation time | Worker startup log |
| ccworker.Log level.Log generation time | Worker run log | |
| Sidecar log | cc-sidecar-zk.log | ZooKeeper operation log of sidecar |
| cc-sidecar-bg-task.log | Sidecar backend task log | |
| cc-sidecar-cli.log | Sidecar command execution log | |
| cc-sidecar.log | Sidecar run log |
Log levels
Table 2 describes the log levels provided by MemArtsCC.
The log levels are ERROR, WARN, INFO, and DEBUG in descending order of priority. Only logs whose levels are higher than or equal to the specified level are recorded. The higher the log level specified, the fewer the logs are recorded.
| Level | Description |
| ERROR | Logs of this level record error information about system running |
| WARN | Logs of this level record exception information about the current event processing |
| INFO | Logs of this level record normal running status information about the system and events |
| DEBUG | Logs of this level record the system information and system debugging information |
To modify log levels, perform the following operations:
- Choose Cluster > Services > MemArtsCC. Click Configurations and then All Configurations.
- On the menu bar on the left, select the log menu of the target role.
- Select a desired log level.
- Click Save. In the displayed dialog box, click OK to save the configuration.
- Click Instances, select all CCSideCar instances, and choose More > Restart Instance.
Upon completing the configuration, a restart of CCSideCar is necessary. There is no need to restart CCWorker.
