On this page
Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using Doris/ Common Issues About Doris/ How Do I Handle the Startup Failure Due to Incorrect IP Address Matching for the BE Instance?
Updated on 2024-10-25 GMT+08:00
Symptom
The BE instance failed to be started and the following error message was displayed:
backend ip saved in master does not equal to backend local ipx.x.x.x vs. x.x.x.x
Cause Analysis
The BE installation node has multiple network adapter IP addresses. The priority_network parameter is incorrectly set. As a result, an incorrect IP address is matched during BE startup.
  1. Log in to FusionInsight Manager and choose Cluster > Services > Doris, and click Configurations.
  2. Search for the priority_network parameter and set it correctly for the BE service. You can view the IP address of the network adapter bound to the BE node by checking the CURRENT_INSTANCE_IP variable in BE installation directory/FusionInsight_Doris_*/1_*_BE/etc/ENV_VARS.
    The priority_network parameter is used to help the system select the correct IP address of the network adapter as the IP address of the FE or BE. You are advised to set this parameter explicitly in any case to prevent incorrect IP address selection after network adapters are added. The value of priority_network is in CIDR format and is used to ensure that all nodes can use the same configuration value. The parameter value consists of two parts. The first part is the IP address in dotted decimal notation, and the second part is the prefix length.
    For example, 10.168.1.0/8 matches all 10.xx.xx.xx IP addresses, and 10.168.1.0/16 matches all 10.168.xx.xx IP addresses. If there are two nodes: 10.168.10.1 and 10.168.10.2, 10.168.10.0/24 can be the value of priority_network.
