Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using Doris/ Typical SQL Syntax of Doris/ DROP TABLE
DROP TABLE
This section describes the basic SQL syntax and usage of Doris for deleting tables.
Basic Syntax
DROP TABLE [IF EXISTS] [db_name.]table_name [FORCE];
Use Example
Delete the my_table table.
DROP TABLE IF EXISTS example_db.my_table;
Parent topic: Typical SQL Syntax of Doris
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
