INSERT INTO
This section describes the basic syntax and usage of SQL statements for inserting table data to the Doris.
Basic Syntax
INSERT INTO table_name
[ PARTITION (p1, ...) ]
[ WITH LABEL label]
[ (column [, ...]) ]
[ [ hint [, ...] ] ]
{ VALUES ( { expression | DEFAULT } [, ...] ) [, ...] | query }
Use Example
- Insert multiple rows of data into the test table at a time.
INSERT INTO test VALUES (1, 2), (3, 4);
 - Import the result of a query statement to the test table.
INSERT INTO test (c1, c2) SELECT * from test2;
