Adding Third-Party Dependency JAR Packages to a FlinkServer Job
This topic is available for MRS 3.3.0 or later only.
Flink allows you to run user-defined Flink jobs using third-party dependency packages. You can upload and manage dependency JAR packages on the Flink web UI and invoke required dependencies when running jobs. The dependency management function does not support semantic verification. A dependency JAR package name must start with a letter, digit, or underscore (_) and cannot exceed 32 characters. The following third-party dependencies are supported:
- Custom connector dependency: After a custom connector JAR package is uploaded, Dependency Type is connector on the Flink web UI.
- Non-custom connector dependency: After a non-custom connector JAR package, such as a job dependency package, is uploaded, Dependency Type is normal on the Flink web UI.
To use this function, you need to prepare the dependency files. If you upload dependencies to the cluster by specifying a path, you need to create an HDFS path and upload the JAR package to the HDFS.
Uploading Dependency Packages
- Log in to FusionInsight Manager and access the Flink web UI. For details, see Accessing the FlinkServer Web UI.
- Click Dependency Management. The Dependency Management page is displayed.
- Click Add Dependency.
Table 1 Adding a dependency Parameter
Example
Customized connector or not
Whether the dependency is a custom connector. Set this parameter based on the site requirements.
- Yes: The file is a custom connector dependency.
- No: The file is a non-custom connector dependency.
Yes
Name
Name of the dependency, which must be the same as the connection name of connector in the uploaded dependency package. Dependency packages with the same name cannot be uploaded.
kafka
Register jar
Upload method of a JAR package:
- Upload File: Upload a JAR package form the local host.
- Specify Path: Upload a prepared dependency file from an HDFS path.
Uploading files
Upload File
If Register jar is set to Upload File, select a JAR file from the local host.
Specify Path
If Register jar is set to Specify Path, enter the HDFS path of the dependency file. (The JAR package must have been uploaded to the HDFS.)
/flink_upload_test/flink-connector-kafka-customization.jar
Description of the dependency to be uploaded.
- Click OK
Example
- Custom connector dependencies
- Upload a custom connector dependency by referring to Uploading Dependency Packages.
For example, the dependency name is kafka, and the name of the custom connector JAR package is flink-connector-kafka-customization.jar.
- Create a SQL job by referring to Creating a Job. Set connector in the SQL statement to the dependency name, for example, 'connector'='kafka'.
CREATE TABLE KafkaSinkTable (`user_id` INT, `name` VARCHAR) WITH ( 'connector' = 'kafka', 'topic' = 'test_sink6', 'properties.bootstrap.servers' = '192.168.20.134:21005', 'properties.group.id' = 'testGroup', 'scan.startup.mode' = 'earliest-offset', 'format' = 'csv' ); CREATE TABLE datagen (`user_id` INT, `name` VARCHAR) WITH ( 'connector' = 'datagen', 'rows-per-second' = '5', 'fields.user_id.kind' = 'sequence', 'fields.user_id.start' = '1', 'fields.user_id.end' = '1000' ); insert INTO KafkaSinkTable select * from datagen;
- Non-Custom connector dependencies
Upload a non-custom connector dependency for a job. For details, see Uploading Dependency Packages.
