Help Center/
MapReduce Service/
Component Operation Guide (LTS)/
Using HBase/
Hot-Cold Data Separation/
Enabling the Hot-Cold Data Separation
Updated on 2024-05-29 GMT+08:00
You can modify the HBase configuration on FusionInsight Manager to enable hot-cold data separation. Cold data will be stored in OBS and hot data will be stored in HDFS.
- Interconnecting the Guardian Service with OBS
- Log in to FusionInsight Manager, choose Cluster > Services > HBase, and click Configuration. Search for and modify the following parameters:
- fs.coldFS: OBS file system name, for example, obs://OBS parallel file system name
- hbase.fs.hot.cold.enabled: The default value is false. Set this parameter to true.
- fs.obs.buffer.dir: Set this parameter to the directory of the locally mounted data disk, for example, /srv/BigData/data1/tmp/HBase/obs.
- Click Save.
- Click Dashboard and click More > Restart Service to restart the HBase service. After the service is restarted, hot-cold data separation is enabled.
- Set the cold and hot boundary for the table data. For details, see Cold-Hot Separation Commands.
Parent topic: Hot-Cold Data Separation
