Updated on 2026-06-27 GMT+08:00
SHOW_COMMIT_FILES
Notes and Constraints
This section applies only to MRS 3.3.0-LTS or later.
Function
This command is used to check the number of files updated or inserted during a specific instant.
Syntax
call show_commit_files(table=>'[table]', instant_time=>'[instant_time]', limit=>'[limit]');
Parameters
Table 1 Parameter description
Mandatory
table
Name of the table to be queried. The value can be in the database.tablename format.
Yes
instant_time
Timestamp corresponding to a commit operation
Yes
limit
Number of returned items
No
Example
call show_commit_files(table=>'hudi_mor', instant_time=>'20230216144548249');
call show_commit_files(table=>'hudi_mor', instant_time=>'20230216144548249', limit=>'1');
Returned Result
action
Action type of the commit operation corresponding to instant_time, such as compaction, deltacommit, and clean
partition_path
Partition where the file updated in or inserted to a specified instant is located
file_id
ID of the file updated in or inserted to the specified instant
previous_commit
Timestamp in the file name updated or inserted by the specified instant.
total_records_updated
Number of updated records in the file
total_records_written
Number of records inserted into the file
total_bytes_written
Number of bytes of data added to the file
total_errors
Total number of errors reported during the update in or insertion to the specified instant
file_size
File size, in bytes
Response
You can view query results on the client.
