CLEANARCHIVE
Notes and Constraints
This section applies only to versions MRS 3.2.1-LTS through MRS 3.3.1-LTS.
Function
This command is used to clean up Hudi archive files. This process reduces storage consumption and minimizes performance pressure on Hudi tables.
Syntax
set hoodie.archive.file.cleaner.policy = KEEP_ARCHIVED_FILES_BY_SIZE;
set hoodie.archive.file.cleaner.size.retained = 5368709120;
run cleanarchive on tableIdentifier/tablelocation;
set hoodie.archive.file.cleaner.policy = KEEP_ARCHIVED_FILES_BY_DAYS;
set hoodie.archive.file.cleaner.days.retained = 30;
Parameter Description
| Parameter | Description |
| tableIdentifier | Name of the Hudi table |
| tablelocation | Storage path of the Hudi table |
| hoodie.archive.file.cleaner.policy | Policy for clearing archived files: Currently, only the KEEP_ARCHIVED_FILES_BY_SIZE and KEEP_ARCHIVED_FILES_BY_DAYS policies are supported. The default policy is KEEP_ARCHIVED_FILES_BY_DAYS.
| hoodie.archive.file.cleaner.size.retained | When the policy is set to KEEP_ARCHIVED_FILES_BY_SIZE, this parameter specifies the total bytes of archived files to retain. The default value is 5368709120 bytes (5 GB). |
| hoodie.archive.file.cleaner.days.retained | When the policy is set to KEEP_ARCHIVED_FILES_BY_DAYS, this parameter specifies the number of days to retain archived files. The default value is 30 days. |
Precautions
Archived files are not backed up. Once deleted, these files cannot be restored.
Response
You can view command execution results in the driver log or on the client.
