Submitting a Spark Job as a Proxy User
This section applies only to MRS 3.3.0 and later versions.
Submit a Spark task as the actual running user or a proxy user. This section describes how to enable the proxy user function to submit Spark tasks.
The test (actual running user) and test1 (proxy user) users have been created and added to the hadoop (primary group), hive, and supergroup groups.
Submitting a Spark Task as a Proxy User in spark-beeline
  1. Modify JDBCServer instance parameters.
    Log in to FusionInsight Manager and choose Cluster > Services > Spark. Click Configurations, click All Configurations, click JDBCServer(Role), select Customization, find the spark.core-site.customized.configs parameter, and add the following custom parameters:
    Value
    hadoop.proxyuser.test.hosts
    hadoop.proxyuser.test.groups
    • In the configuration, test is the actual running user.
    • The value of hadoop.proxyuser.test.hosts is *, which indicates that any proxy user can be used after user test is connected and the number of cluster nodes is not limited.
    • The value of hadoop.proxyuser.test.groups is *, which indicates that any proxy user can be used after user test is connected and the proxy user can belong to any user group.
  2. Change the values of the following parameters to switch to the JDBCServer multi-instance mode:
    Value
    spark.scheduler.allocation.file
    #{conf_dir}/fairscheduler.xml
    spark.thriftserver.proxy.enabled
    false
  3. Save the configuration and restart the Spark service.
  4. Log in to the Spark client node and run the following commands:
    cd Client installation directory
    source bigdata_env
    source Spark/component_env
    In security mode, additionally run the following command:
    kinit test Enter the password for authentication. (Change the password upon your first login.)
  5. Run the following Beeline commands of Spark to submit a task:
    cd /opt/client/Spark/spark/bin
    ./beeline
    !connect jdbc:hive2://IP address of the node where the ZooKeeper instance is:Port number of the ZooKeeper client,IP address of the node where the ZooKeeper instance is:Port number of the ZooKeeper client,IP address of the node where the ZooKeeper instance is:Port number of the ZooKeeper client/;serviceDiscoveryMode=zooKeeper;zooKeeperNamespace=sparkthriftserver;saslQop=auth-conf;auth=KERBEROS;principal=spark2x/hadoop.hadoop.com@HADOOP.COM;hive.server2.proxy.user=test1
    Specifically:
    • IP address of the node where the ZooKeeper instance is: To obtain the IP address, on FusionInsight Manager, choose Cluster > Services > ZooKeeper and click Instance.
    • Port number of the ZooKeeper client: To obtain the port number, on FusionInsight Manager, choose Cluster > Services > ZooKeeper, click Configurations then All Configurations, and search for clientPort.
    • hive.server2.proxy.user=test1: test1 is a proxy user.
  6. Create a Spark table.
    create table sparktest1(a string,b int);
    View the created table.
    desc formatted sparktest1;
    You can see that Owner of the table is the proxy user test1, and the proxy user is successfully used.
Submitting a Spark Task as a Proxy User in spark-sql and spark-submit
  1. Modify the HDFS instance configuration. Log in to FusionInsight Manager and choose Cluster > Services > HDFS. Click Configurations then All Configurations, click HDFS(Service), select Customization, find the hdfs.core-site.customized.configs parameter, add the following custom parameters, and save the configuration:
    Value
  2. Modify the Yarn instance configuration. Log in to FusionInsight Manager and choose Cluster > Services > Yarn. Click Configurations then All Configurations, click Yarn(Service), select Customization, find the yarn.core-site.customized.configs parameter, add the following custom parameters, and save the configuration:
    Value
  3. Modify the SparkReource instance configuration. Log in to FusionInsight Manager and choose Cluster > Services > Spark. Click Configurations then All Configurations, click SparkResource(Role), select Customization, find the spark.core-site.customized.configs parameter, add the following custom parameters, and save the configuration:
    Value
  4. Modify the Hive instance configuration. Log in to FusionInsight Manager and choose Cluster > Services > Hive. Click Configurations then All Configurations, click Hive(Service), select Customization, find the core.site.customized.configs parameter, add the following custom parameters, and save the configuration:
    Value
  5. Restart the HDFS, YARN, Spark, and Hive services and update the configuration files on their clients.
  6. Log in to the Spark client node and run the following commands:
    source bigdata_env
  7. Submit the spark-sql task.
    spark-sql --master yarn --proxy-user test1
  8. Create a Spark table.
    create table sparktest2(a string,b int);
    desc formatted sparktest2;
  9. Use the redelivered client to submit the spark-submit task.
    spark-submit --master yarn --class org.apache.spark.examples.SparkPi --master yarn-client --proxy-user test1 /opt/client/Spark/spark/examples/jars/spark-examples_*.jar
  10. View information about applications running in YARN.
    You can see that the running user of the task is test1, and the proxy user is successfully used.
