Accelerating ClickHouse Merge
To accelerate background tasks, adjust the ZooKeeper service configuration first. Otherwise, the ClickHouse service and background tasks will be abnormal due to insufficient ZooKeeper resources such as znodes.
- Adjust the ZooKeeper configuration. Log in to FusionInsight Manager and choose Cluster > Services > ZooKeeper. Click Configurations and then All Configurations. Click quorumpeer > System, change the value of GC_OPTS according to the following table, save the configuration, and roll restart the ZooKeeper service.
Configuration Item
Reference Value
GC_OPTS
JVM parameter used for garbage collection (GC). This parameter is valid only when GC_PROFILE is set to custom. Ensure that GC_OPT is correctly set. Otherwise, the process will fail to start.
CAUTION:Exercise caution when modifying this item. If this parameter is set incorrectly, the service will be unavailable.
Xmx = (Memory size of Master nodes – 16 GB) x 0.65 (conservative estimation)
- Adjust the ClickHouse configuration. On FusionInsight Manager, choose Cluster > Services > ClickHouse. Click Configurations and then All Configurations. Click ClickHouseServer > Zookeeper, modify the following parameters, and save the settings. You do not need to restart the service.
Configuration Item
Reference Value
clickhouse.zookeeper.quota.node.count
Node quantity quota of ClickHouse in the top directory on ZooKeeper.
This parameter cannot be set to 0, but can be set to a minimum value of –1. –1 indicates that there is no limit on the number of ClickHouse nodes in the top directory.
If the quantity quota is less than the actual value of the current ZooKeeper directory, the configuration can be saved but does not take effect and an alarm is reported on the GUI.
6000000
clickhouse.zookeeper.quota.size
Capacity quota of ClickHouse in the top directory on ZooKeeper.
Xmx x 1 GB
