HetuEngine SQL Diagnosis
The HetuEngine QAS module provides automatic detection, learning, and diagnosis of historical SQL execution records for more efficient online SQL O&M and faster online SQL analysis. After SQL diagnosis is enabled, the system provides the following capabilities:
- Automatically detects and displays tenant-level and user-level SQL execution statistics in different time periods to cluster administrators, helping them quickly predict service running status and potential risks.
- Automatically diagnoses large SQL statements, slow SQL statements, and related submission information, displays the information in multiple dimensions for cluster administrators, and provides diagnosis and optimization suggestions for these statements.
This section applies to MRS 3.2.0 or later.
- The cluster is running properly and at least one QAS instance has been installed.
- You have created a user for accessing the HetuEngine web UI, for example, Hetu_user. For details, see Creating a HetuEngine Permission Role.
Enabling SQL Diagnosis
The SQL diagnosis function of HetuEngine is enabled by default. You can perform the following steps to configure other common parameters or retain the default settings:
- Log in to FusionInsight Manager as user Hetu_user.
- Choose Cluster > Services > HetuEngine. Click Configurations then All Configurations, click QAS(Role), and select SQL Diagnosis. If qas.sql.auto.diagnosis.enabled is set to true, the SQL diagnosis function is enabled. In this case, you can configure recommended SQL diagnosis parameters based on service requirements.
- Click Save.
- Click Instance, select all QAS instances, click More, and select Restart Instance. In the displayed dialog box, enter the password to restart all QAS instances for the parameters to take effect.
Viewing SQL Diagnosis Results
- Choose Cluster > Services > HetuEngine to go its service page.
- In the Basic Information area on the Dashboard page, click the link next to HSConsole WebUI. The HSConsole page is displayed.
- Choose SQL O&M to view SQL diagnosis results.
- On the Overview page, you can view the overall running status of historical tasks, including the query duration distribution chart by segment, query user distribution chart, total submitted SQL queries, SQL execution success rate, average SQL query response time, number of queries, average execution time, and average waiting time.
- On the Slow Query Distribution page, view the slow query distribution of historical tasks, including:
- Slow SQL statistics: collects statistics on the number of slow queries (the query time is greater than the slow query threshold) submitted by each tenant.
- Top users with the maximum slow query requests: collects statistics on slow query statistics of each user. The statistics can be sorted in a list and exported.
- On the Slow Queries page, view the slow query list of historical tasks, diagnosis results, and optimization suggestions. Query results can be exported.
The validity period of historical statistics depends on the JVM memory size of HSConsole instances and cannot exceed 60 days.
