Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using ClickHouse/ Common Issues About ClickHouse/ How Do I handle the Error Occurred During Table Data Synchronization via Auxiliary ZooKeeper or Replica Data?
Updated on 2025-08-22 GMT+08:00
Question
An error is reported in logs when the auxiliary ZooKeeper or replica data is used to synchronize table data.
DB::Exception: Cannot parse input: expected 'quorum:' before: 'merge_type: 2'...
Too many parts (315). Merges are processing significantly slower than inserts...
Answer
The versions of replication table replicas are inconsistent, causing compatibility issues. The table schema contains TTL statements. TTL_DELETE is added in versions later than ClickHouse 20.9, which cannot be identified in earlier versions. This issue occurs when the replication table replica of a later version is elected as the leader.
You can modify the config.xml file of ClickHouse of a later version to avoid such an issue. Ensure that the replication table replicas are the same as those of ClickHouse.
