Updated on 2026-06-27 GMT+08:00
How Do I Migrate Data from OBS to ClickHouse?
Question
How do I migrate data from OBS/S3 to MRS ClickHouse?
Answer
  1. Query data stored in S3.
    select * from s3(path [,access_key_id, secret_access_key] [,format] [,structure])
    • path: bucket URL with a file path.
    • format: The file format.
    • access_key_id and secret_access_key: long-term credentials of an account. Credentials can be used to authenticate requests. These parameters are optional. If no credential is specified, credentials are read from the configuration file.
    • structure: The table schema.
  2. Obtain data from S3 to create a table.
    CREATE TABLE test1_s3 (name String, value UInt32) ENGINE = S3(path, [access_key_id, secret_access_key,] format)
  3. View the created table.
    select * from test1_s3
