Updated on 2026-06-27 GMT+08:00
CLUSTERING
Notes and Constraints
This section applies only to MRS 3.2.0-LTS or later.
Function
Performs the clustering operation on Hudi tables. For details, see Hudi Clustering.
Syntax
  • Performing clustering:
    call run_clustering(table=>'[table]', path=>'[path]', predicate=>'[predicate]', order=>'[order]');
  • Viewing the clustering plan:
    call show_clustering(table=>'[table]', path=>'[path]', limit=>'[limit]');
Parameter Description
Table 1 Parameters
Mandatory
table
Name of the table to be queried. The value can be in the database.tablename format.
No
path
Path of the table to be queried
No
predicate
Predicate to be defined
No
order
Sorting field for clustering
No
limit
Number of query results to display
No
Example
call show_clustering(table => 'hudi_table1');
call run_clustering(table => 'hudi_table1', predicate => '(ts >= 1006L and ts < 1008L) or ts >= 1009L', order => 'ts');
call run_clustering(path => '/user/hive/warehouse/hudi_test2', predicate => "dt = '2021-08-28'", order => 'id');
Precautions
  • Either table or path must exist. Otherwise, the Hudi table to be clustered cannot be determined.
  • To cluster a specified partition, refer to the format predicate => "dt = '2021-08-28'".
Response
You can view query results on the client.
