SAVE_POINT
Function
Manages savepoints of Hudi tables.
Syntax
Parameter Description
| Parameter | Description | Mandatory |
| table_name | Name of the table to be queried. The value can be in the database.tablename format. | Yes |
| commit_Time | Specified creation or rollback timestamp | Yes |
| user | User who creates a savepoint | No |
| comments | Description of the savepoint | No |
| savepoint_Time | Timestamp indicating when a savepoint was created | Yes |
Example
call create_savepoint('hudi_test1', '20220908155421949');
call show_savepoint(table =>'hudi_test1');
call rollback_savepoint('hudi_test1', '20220908155525378'); Precautions
- MOR tables do not support savepoints.
- The commit-related files before the latest savepoint are not cleaned.
- If there are multiple savepoints, perform the rollback from the latest savepoint. The logic is as follows: roll back the latest savepoint; delete the savepoint; and roll back the next savepoint.
Response
You can view query results on the client.
