Updated on 2026-06-27 GMT+08:00
Typical Impala Configurations
This section applies to MRS 3.x or later.
Page Access
On Manager, choose Cluster > Services > Impala. On the page that is displayed, click the Configuration tab then the All Configurations sub-tab. Enter a parameter name in the search box.
Parameter Description
The following table lists only some common parameters. The actual parameters are subject to the FusionInsight Manager page. For details, visit the official website at https://docs.cloudera.com/documentation/enterprise/6/properties/6.3/topics/cm_props_cdh630_impala.html.
Table 1 Common Impala parameters
Default Value
Value Range
--enable_ldap_auth
Whether to enable LDAP authentication
false
The value can be true or false.
--ldap_bind_pattern
ldap userDNPattern, for example, cn=%s,ou=People,dc=huawei,dc=com
N/A
N/A
--ldap_passwords_in_clear_ok
If this parameter is set to true, LDAP passwords are sent in plaintext (excluding TLS and SSL) on the network.
false
--max_log_files
Maximum number of process log files
10
N/A
--max_log_size
Maximum size of a process log file, in MB
200
N/A
impalad.customized.configs
Custom configuration item of the impalad process
N/A
N/A
statestored.customized.configs
Custom configuration item of the Statestored process
N/A
N/A
catalogd.customized.configs
Custom configuration item of the Catalogd process
N/A
N/A
--default_query_options
Default query options in key=value format, separated by commas (,). Once configured, these options apply to all queries globally. To apply the options to a single query, use the set command to configure it separately.
fetch_rows_timeout_ms=10000
N/A
