SET
Function
The ALTER TABLE ... SET|UNSET command is used to modify table properties.
Syntax
ALTER TABLE Table name SET|UNSET tblproperties
Parameter Description
Parameter |
Description |
tableName |
Table name. |
tblproperties |
Table properties. |
Example
ALTER TABLE table SET TBLPROPERTIES ('table_property' = 'property_value')
ALTER TABLE table UNSET TBLPROPERTIES [IF EXISTS] ('comment', 'key')
Response
You can run the DESCRIBE command to view new table properties.
