DROP COLUMN
Function
The ALTER TABLE ... DROP COLUMN command is used to delete a column.
Syntax
ALTER TABLE tableName DROP COLUMN|COLUMNS cols
Parameter Description
        Parameter  |
        Description  |
        tableName  |
        Table name.  |
        cols  |
        Columns to be deleted. You can specify multiple columns.  |
Example
ALTER TABLE table1 DROP COLUMN a.b.c ALTER TABLE table1 DROP COLUMNS a.b.c, x, y
a.b.c indicates the full path of a nested column. For details about the nested column rules, see ADD COLUMNS.
Response
You can run the DESCRIBE command to check which column is deleted.
