ADD COLUMNS
Function
The ADD COLUMNS command is used to add a column to an existing table.
Syntax
ALTER TABLE Table name ADD COLUMNS(col_spec[, col_spec ...])
Parameter Description
| Parameter | Description |
| tableName | Table name. |
| col_spec | Column specifications, consisting of five fields, col_name, col_type, nullable, comment, and col_position.
Example
alter table h0 add columns(ext0 string); alter table h0 add columns(new_col int not null comment 'add new column' after col1); alter table complex_table add columns(col_struct.col_name string comment 'add new column to a struct col' after col_from_col_struct);
Response
You can run the DESCRIBE command to view the new column.
